NICE NEOMAT tubular motor
  • Hello,
    My name is Patrick, I am new to this forum.
    I am looking to operate a roller shutter motor with a Shelly 1 module to replace a push button.
    In fact, to control the automation I use a push button between the Common wire and the Step-by-Step input.
    The operating mode follows this sequence: Up-stop-Down-stop.
    If the button is held down for more 3 seconds (but less than 10 seconds), an UP movement is always activated (this action corresponds to the key UP on the radio controls).
    If the button is held down for more 10 seconds, a DOWN movement is always activated (corresponding to key Down on the radio contols).
    Today, I use a radio remote control at 433.92Mhz to operate this motor.
    The purpose is to use these 2 wires with the Shelly 1 module and to be controlled by Alexa (Echo Dot) by creating a script in line with the timing as described above in my message.
    FYI, Shelly 1 is already paired with Alexa and and reacts to the orders sent to it.
    Thanks in adance for your support ;)
    Patrick
  • Welcome to the forum!
    What is your question? The issue seems to be solvable with your ideas…
    But you should use a Shelly plus 1 due to its SELV permission. AND the Shelly plus 1 is capable to work with scripts.
    Only my 10 cents…
  • Hello thgoebel,
    Thanks for your quick reply.
    Sorry, I expressed myself incorrectly; it is indeed the Shelly Plus 1 module.
    To answer your question, I would like someone to help me to write the script to make this engine working with this module.
    My skill level allows me to program small applications under Arduino.
    But here, I don't know how to start and how to upload my program to the module.
    Patrick
  • Sorry, Patrick - scripting is not my main focus area!
