VOUT + R1 ref meaning
  • Hi,
    I have a shelly 1 pm plus and an addon, and a thermistor NTC (24 kohms at +5 degrees, 10 kohms at +20 degrees)
    The doc has this ratings https://kb.shelly.cloud/knowledge-base/shelly-plus-add-on
    Output circuits ratings
    VCC max. current:
    10 mA
    VREF OUT max. current:
    1 mA
    VREF+R1 OUT resistor
    10 kΩ
    So it seems my thermistor is out of range, right ?
    I was hoping to more or less follow the setup described here : https://kb.shelly.cloud/knowledge-base…-photoresistor-
    Now I'm trying to understand a bit deeper how things work : is R1 here an internal resistance of the addon ? If so, do we know its value ?
    I tried to wire the thermistor between GND, ANALOG IN and VREF + R1 OUT and got some voltage readings around 6v in Shelly UI, but not very stable, changing constantly between ~ 5.80 and 6.20v (at a 17 degrees place).
  • Better than words would be an insight at the innards:
    R1 = 10kΩ.
    Hope that helps!
    Einmal editiert, zuletzt von thgoebel (12. Dezember 2023 um 18:05)
  • Thanks !
    Actually I read the add on characteristics again and found this mention :
    Supported sensors
    • Up to 5 DS18B20
    • Single DHT22
    • NTC resistors with 10 kΩ nominal resistance and β=4000 K
    I'm not sure if my thermistor qualifies with this requirement but it doesn't look too far off 🤔
  • So I now have a bit of data to share, and the results aren't really great (the voltage difference being quite low so accuracy wouldn't so good I guess).
    voltage at around 18.1° : ~ 6.2v
    voltage at around 5.5° : ~ 7.4v
    temperature comes from a ds18b20 sensor really close to the thermistor
    Any idea if I could improve a bit on this ?
  • Obviously, your NTC has the appropriate mutual conductance (β factor). Thus, the variance of resistance is too small at the given temperature band.
