Shelly Plus 1 for gate opener
  • I installed a Shelly Plus 1 to operate an electric gate at my home. I currently have the relay set to Auto-Off after 0.5 seconds which simulates a button press for the remote.
    However, I would also like to have an option where I can hold the gate open until indefinitely by closing the dry contacts until the turn the relay off. Is there a way to have multiple "buttons" in the Shelly app that I can press depending on the desired outcome?
    For example, another mode would be "hold open for 10 minutes"
    Any ideas on how I can do this?
  • Dies funktioniert nicht über eine Schaltfläche in der App. Alles, was Sie tun können, ist einen Knopf zu drücken. Eine Möglichkeit wäre, einen Http-Befehl mit entsprechendem Timer zu nehmen und bei Bedarf auszuführen.
    HTTP-Request Shelly PLUS 1
    HTTP-Befehle sollten den eingestellten Timer von 0,5 ignorieren.
  • I think I misunderstood it a little. Sorry.
    Scenes is the way to go if you're working with the cloud.
    Create a scene called Gate open for 10min.
    Select a date and time in the distant future as the trigger in the scene.
    Then switch on the Shelly plus 1 and switch it on again after 10 minutes.
    You can then always play this scene manually in the app using the play button.
    Without a scene, a second Shelly would be possible.
