Why Shelly H&T web UI is not reachable at any time with USB power supply ?
  • Hello,
    I bought a Shelly H&T sensor with USB power supply, it works.
    But I can't get to the HTTP web UI at any time, despite the always-on USB power supply.
    I can understand with a battery that power/energy has to be saved, but why Shelly H&T web UI is not reachable at any time with USB power supply ?
  • This device is not meant to operate 24/7. it will wake up periodically to send new values. You can waki it up by pressing the button with a pin-then you have 3minutes before it goes to sleep again. you can try the
    Min reconnect timeout-value (internet&security--> advanced developer settings --> mqtt) here i can wake mine up every x minutes (5-6 is a good setting).
