FW upgrade often produces no effect
  • Hello,
    I've just upgraded FW of all my Shelly devices to FW version 1.0.8.
    I observed not only with this upgrade but with previous ones as well, that often the upgrade produces no effect. Once concluded and device gets connected again, the FW version remains the same.
    Some devices may take 2 or 3 attempts to get the FW effectively upgraded.
    Is it normal? It's only me? Or there is some advice to make it work mre reliably?
    Fernando
  • There are currently some problems when trying to install the new firmware via the app or control.shelly.cloud. Several attempts are often necessary here.
    If in doubt, it is better to initiate the update via the WEB UI.
    However, the problem is known and will hopefully be solved soon...
