Shelly plus 1PM mini installation
  • Hi all,
    I’m trying to install a Shelly plus 1PM mini, but it’s kind of a strange situation.
    The setup is:
    - Live wire connected to a switch “L” connector
    - Neutral wire connected to the same switch “1” connector
    (No extra wires available, see attachment)
    I know how to connect 3 of the 4 connections on the shelly plus 1PM mini, but it looks I’m missing an extra wire for the “O” (output) connector? (See second attachment)
    Can someone please confirm or show me where I should connect the “O” connector?
    Thanks!
  • I don’t really think this is N and L. If this is really N and you would switch, this would be a short circuit and the fuse would blow. Please check with a two-pole voltage tester. And consult a specialist.
