Shutdown shelly 1PM
  • Hello devil,
    yes, I mean Switching off, alternatively
    is it possible to deactivate the wifi? so that the device behaves like a very common mechanical switch?
    Thank you
    Regards
    Lorenzo
  • you can turn off wifi.. (untick it..) but not sure why would you want that.. If you turn it off you will loose access to it and wont be able to get onto it without factory resetting.. if you are going to do that then enable AP and if you want to set password to the 1pm broadcasted wifi.. that way you can connect directly to it to enable wifi again
