Shelly 3EM Exploded after 15 hours of usage, Shelly Pro better ?
  • Hi,
    I got professionally installed a Shelly 3 EM by an Electician in hour house and it was working great for 15 hours. Suddenly in the Moment when we switched off a light there was a big bang , the shelly exploded and the whole house was out of power.
    I searched the internet and found similar issues, this seems to happen quite often.
    No Problem, I returned the shelly via amazon and I will never buy this Shelly 3EM Model again.
    My Problem is: I need such a device to measure power usage. Will the Shelly PRO 3EM be more resistand and stable than the 3EM ? Is it a goog advice to buy the pro model ?
    See attached Foto for the damage
  • Welcome to the forum!
    Thanks for your description of the Shelly failure! Was it a neon tube which was switched off?
    With some likelihood on of three diodes which rectify the three phase voltage at terminals VA, VB and VC got defective. This causes a three phase short with a lot of short circuit current…
    Shelly pro 3EM avoids this failure mechanism: Supply for the device is fed by one terminal only (C); the other two terminals (A and B) are for measuring purposes only. This seems to be a big step for reliability!
  • Brillant idea to drop the neon light! An earlier change could have saved a Shelly’s 3EM life…
