size limit of 15000 bits
Hinweis für Entwickler
  • Hi, I used shelly script to control my pool pump with temperature.
    I started to make this script with 0.12 firmware version and not i'm with 0.14.
    With new version 1.0.3, the script must be less than 15000 bits !!! can you update this limit ?, my script is 30kbit.
    I would like update my script in order to use shelly addon to plu température sensor, but i can't improve or just commit my script with this limit.
    https://github.com/sylvaing/shelly-pool-pump
  • You would have to contact the manufacturer directly via a support ticket. As far as I am informed, this limit will be raised again. Temporarily only the possibility remains to divide on several scripts.
  • You cannot have both, ether >FW 1.0 or large code files, I got to the point where I just concentrate on doing a toolbox, so some code I can use inside my main code to reduce the main code, while keeping of this toolbax a version thats readable and a version thats kompressed. Also there are a lot of lifehacks to reduce the code size like renaming functions, so ---> GetStatus = Shelly.getComponentStatus;, now you can just use GetStatus('switch',0); inside your main code.
    And some new FW1.0 functions and Syntax can help to reduce the code futher, like "inline if" , for x of y, for x in y, try catch and switch case are working since fw1.0
    inline if ---> true ? DoStuff() : DoOtherStuff();
    Here is a list of stuff i found working inside FW1.0.
    while()
    else if ()
    else {}
    return
    Timer.set()
    Timer.clear()
    this
    typeof
    try
    if()
    in
    Object.keys()
    print()
    arguments.length
    Array.isArray()
    atob()
    Shelly.call()
    Shelly.addEventHandler()
    Shelly.addStatusHandler()
    Shelly.removeEventHandler()
    Shelly.removeStatusHandler()
    Shelly.emitEvent()
    Shelly.getComponentConfig()
    Shelly.getDeviceInfo()
    Shelly.getCurrentScriptId()
    switch()
    die()
    Date.now()
    Date.parse()
    do()
    delete
    function
    Function.replaceWith()
    for()
    HTTPServer.registerEndpoint()
    JSON.parse()
    JSON.stringify()
    let
    chr()
    console.log()
    case()
    continue
    catch
    var
    BLE.Scanner.SCAN_START
    BLE.Scanner.SCAN_STOP
    BLE.Scanner.SCAN_RESULT
    BLE.Scanner.INFINITE_SCAN
    BLE.Scanner.subscribe()
    BLE.Scanner.Start()
    BLE.Scanner.Stop()
    BLE.Scanner.isRunning()
    BLE.Scanner.GetScanOptions()
    BLE.GAP.ADDRESS_TYPE_PUBLIC
    BLE.GAP.ADDRESS_TYPE_RANDOM_STATIC
    BLE.GAP.ADDRESS_TYPE_RANDOM_NON_RESOLVABLE
    BLE.GAP.ADDRESS_TYPE_RANDOM_RESOLVABLE
    BLE.GAP.EIR_FLAGS
    BLE.GAP.EIR_SERVICE_16_INCOMPLETE
    BLE.GAP.EIR_SERVICE_32_INCOMPLETE
    BLE.GAP.EIR_SERVICE_128_INCOMPLETE
    BLE.GAP.EIR_SHORT_NAME
    BLE.GAP.EIR_FULL_NAME
    BLE.GAP.EIR_TX_POWER_LEVEL
    BLE.GAP.EIR_DEVICE_ID
    BLE.GAP.EIR_SERVICE_DATA_16
    BLE.GAP.EIR_SERVICE_DATA_32
    BLE.GAP.EIR_SERVICE_DATA_128
    BLE.GAP.EIR_URL
    BLE.GAP.EIR_MANUFACTURER_SPECIFIC_DATA
    BLE.GAP.parseName()
    BLE.GAP.parseManufacturerData()
    BLE.GAP.ParseDataByEIRType()
    BLE.GAP.HasService()
    BLE.GAP.ParseServiceData()
    bind()
    btoa()
    btoh()
    break
    Number.MAX_VALUE
    Number.MIN_VALUE
    Number.NaN
    Number.NEGATIVE_INFINITY
    Number.POSITIVE_INFINITY
    new Number
    new String
    new Array
    new Date
    null
    MQTT.isConnected()
    MQTT.subscribe()
    MQTT.unsubscribe()
    MQTT.publish()
    MQTT.setConnectHandler()
    MQTT.setDisconnectHandler()
    Math.E
    Math.LN10
    Math.LN2
    Math.LOG10E
    Math.LOG2E
    Math.PI
    Math.SQRT1_2
    Math.SQRT2
    Math.abs()
    Math.acos()
    Math.asin()
    Math.atan()
    Math.atan2()
    Math.ceil()
    Math.cos()
    Math.exp()
    Math.floor()
    Math.log()
    Math.max()
    Math.min()
    Math.pow()
    Math.random()
    Math.round()
    Math.sign()
    Math.sin()
    Math.sqrt()
    Math.tan()
    Math.wrap()
    eval();
    HIGH
    LOW
    Infinity
    NaN
    isFinite();
    isNaN();
    parseInt();
    parseFloat();
    throw new Error("Shit hit the Fan!");
    test.length.toFixed()
    test.charAt()
    test.concat()
    test.endsWith()
    test.fromCharCode()
    test.indexOf()
    test.lastIndexOf()
    test.localeCompare()
    test.match()
    test.repeat()
    test.replace()
    test.slice()
    test.split()
    test.startsWith()
    test.substr()
    test.toLowerCase()
    test.toUpperCase()
    test.trim()
    //Array
    //test2.isArray()
    //test2.filter();
    //test2.forEach();
    //test2.join();
    //test2.map();
    //test2.pop();
    //test2.push();
    //test2.some();
    //test2.splice();
    //test2.toString();
    //Date
    //test3.getDate();
    //test3.getDay();
    //test3.getFullYear();
    //test3.getHours();
    //test3.getMilliseconds();
    //test3.getMinutes();
    //test3.getMonth();
    //test3.getSeconds()
    //test3.getTime()
    //Date.now()
    //test3 = Date.parse('2011-10-20');
    //test3.setTime(202344);
    //test3.toISOString();
    //test3.toJSON();
    //test3.toString();
    //test3.toUTCString();
    //test3.valueOf();
    //functions
    //test4.apply();
    //test4.bind();
    //test4.call();
    //new Function("a", "b", "c", "return a+b+c");
    //test4.replaceWith();
    5 Mal editiert, zuletzt von _[Deleted]_ (8. November 2023 um 16:40)
