Smart Switches with API
  • We are looking for a smart switch solution. To explain, our firm
    manages buildings with temporary housing units. The tenants have
    assigned time slots to use the laundry machines. Each tenant has an ID
    card with a barcode. I want for them to be able to pass their ID card
    through a card reader device, and that device will (via a PC) contact
    our server and “ask” if this person has permission to use the machine
    at this time, and if so, it will turn on the laundry machine. Seems
    this could be achieved by a smart switch that could turn off or on the
    electricity to any given machine.
    We have Speed Queen Commercial machines which use a 4-prong 240V
    Commercial dryer power supply.
    The communications part we can handle -- we have a web development
    team. What we need is hardware that can do this. Do you have smart
    switches with an API that could handle this?
    If so, let me know how it would work and please send a link to the
    documentation.
    Thank you,
    David
    Midway Living Web Team
    New York City
  • Welcome to the forum!
    Plase have a look at this diagram:
    776-ar768-drehstromanschluss-png
    Replace in your mind the motor with your laundry machine...
    Manual is downloadable here:
    https://shelly-forum.com/filebase/entry…g-mehrsprachig/
  • I am a web developer and understand the basics of electronics but I am not an electrician. It would appear your solution is based on a unique circuit breaker for each machine, which also makes sense to me and we thought of that.
    The issue is that we don't have that at present. For whatever reasons (or mistakes) each machine does not have a unique circuit -- they share a wire inside the of the wall. I suggested to the boss that we may need to change that, but can you clarify a bit?
    Thank you.
  • Right. Each machine needs a separate WLAN/LAN controlled circuit breaker. It would be brilliant to clarify this:
    Cannot imagine what this means…
