Can Uni accept dry contact input?
  • Welcome to the forum!
    Yes, both digital inputs (IN-1, IN-2) of Shelly UNI may be controlled by dry contacts. One side of the contact must be wired with pin ‘SENS Vcc’, the other with the appropriate input (IN-1 or IN-2).
    Thank you for the welcome and thank you even more for the answer! That's what I was hoping. So I'd wire it like this diagram I suppose?
    Externer Inhalt i.ibb.co
    I'd just need to trial and error which the COM and NC out of my sensor go to on the Shelly
  • It would be more convenient and reliable to use the SENS Vcc pin (4) for the high side of the contacts, as I mentioned above.
