How to connect Shelly to this LED driver?
  • Greetings,
    I have this LED driver and I need to connect it to Shelly Dimmer 2 (or it can be any other Shelly device if it is better), so that 3 steps dimming will work. I connected it to Dimmer 2 before, but if I put 100% light it destroyed the driver. So, now I have a brand new driver (same model) and I need some help with connection, so that I don't destroy it again.
    Thank you in advance :)
    Externer Inhalt www.markenmix.de
  • Obviously, the driver is equipped with an integral dimming function which is controlled by switching on and off in a certain rhythm. Such kind of drivers are not compatible with Shelly Dimmer2. Perhaps you could control the inherent dimming function with a Shelly 1 or plus 1.
