Low voltageswitch to trigger on SW1-SW4 (?? Shelly i5)
  • I am new to the shelly product line and got now my fist shelly's.
    One of them is the Shelly i4 AC version.
    I thought I could attach a simple close switch to the inputs but I am wrong.
    The input is not a high / low signal it is a detected current flow and it uses the 110/230V connector.
    This means I can not use the i4 for for my home automation project, but for some of my other projects it is perfect.
    Question:
    Is there a Shelly available which can simple be used with a low voltage open/close switch instead of using 110/230V ?
    Create would be to have the i4 with a extra 5V/3,3V out connector which can be used to attach the low voltage switch.
    This should be easy as internally is a ESP32 doing the job.
  • Welcome to the forum!
    Did you think about using a Shelly i4DC? It runs and recognises signals with a minimum of 5V DC…
    [product='59'][/product]
    Unfortunately, you’re a but tight-lipped about your plans and ideas. Thus we’ll have to guess what you may need…
  • Thank you for your feedback.
    Yes I did, but I don't have DC provide power to them.
    But I just saw the Shelly Add-on.
    And if I am understanding it correctly I can use that a a hat connect a simple on/off or button to the digital in connector.
    This would solve my requirements.
  • Indeed, a Shelly plus 1 (or another type suitable for Add-On) and an Add-On “plus” would do the job. A simple switch connected between Digital Input and GND shall recognise the setting of the switch.
