Activate radioator if temperature is below 6 degrees
Hinweis für Entwickler
  • Hi!
    Im new to this and have no shelly product yet, but thinking shelly could be good for my cabin, hope you people could help me
    Im thinking of replacing old way to power on my radiators in my cabin.
    Today i have old GSM Fixi to power on radioator true phone, and this allso after power on it control that the temperature is not below 6 degree then it power it on again
    The GSM product is placed in the powercentral and the product is Sicom GSM Fixi
    Now i have internet at the cabin and would like to replace this with new products
    Any ideas would be thankful
    Cheers
  • Really? And what about the 3 16A relays in the Shelly pro 3?
  • I am unsure of the exact load being used, but the radiators I am familiar with consume a significant amount of power. A continuous 10A current would likely damage a Shelly unit, so I suggest using separate relays(Schütz) that could be controlled via Shellys equipped with add-ons and temperature sensors. I do not advise the direct usage of a Shelly for extended high load switching.
  • thgoebel
    28. November 2022 um 15:46
