Shelly H&T Plus shows higher Temperature when connected to USB?
  • Seems the device is showing higher temperature when externally connected to power compared to Battery usage - can that be? Did anybody else notice this and found a solution?
    Not sure if i should adapt this with an offset as the offset may differ based on the room temperature then
  • Welcome to the forum!
    Most likely, the temperature sensor is influenced by the power regulator of the Shelly plus HT! Battery supply does not need such a regulator - thus, the temperature sensor is working as it should…
    The developers have separated very thoroughly the sensor from other electronic parts of the logic board. But some interference does obviously occur.
  • Thanks for the fast response! Unfortunately it's almost a 2 Degree offset, could that really be? Makes the option for external power useless from my understanding...Proven by a battery powered H&T Plus next to the external powered one
  • 2 degrees only? Could be compensated by an offset value in device menue…
