SETTING UP SCENES TO CONTROL WITH ALEXA
  • Greetings to the forum: I installed 6 RGBW2 each to an RGB LED tape, I have created scenes but I have the problem that Alexa does NOT turn the scenes on or off. Separately Alexa does work, but as a group it doesn't. Is there a manual to configure the scenes with RGBW2 or an idea of what is going on.. Thank you
    Edit: Removed Code Block by Moderator
    Einmal editiert, zuletzt von Devil (29. Juni 2023 um 00:26)
  • If you create a group/room directly in Alexa with the 6 RGBW2? Then you should be able to control them there via voice command. At least that's how I know it with other Shellys.
