SHELLY - SWITCH OFF WHEN POWER IS ON FOR XX MINUTES
Hinweis für Entwickler
  • I have a drying oven and every time my employees turn it on it stays "eternally on", with a huge waste of energy and costs, I want a device that detects that it is on and after x time turn off.
    Is there any Shllyr products that can do this?
    Thanks
  • Welcome to the forum!
    The simplest way to solve the issue would be,to detect the on condition by measuring the current of the oven an to start an auto-off timer if current is over a certain limit. To give you a recommendation for a certain Shelly device, we need some more information about the oven: Power consumation, one, two or threee phase connection to mains supply…
  • If it were a small current consumption of up to 2500W, then a smart socket with consumption measurement and a script for automatic shutdown would be enough. The smart socket can be turned on manually at any time with one button.
    M.
