Shelly EM/3EM Empfangstärke ausreichend?
    mein Shelly Em misst die Solaranlage und HA wertet gemeinsam mit Shelly 3EM den kompletten Verbrauch aus. Auch saldierend, da ja 3EM das so nicht kann.
    Leider verliert HA immer wieder den Sensor "Energy Export daily". Die Experten bei HA sind hier auch etwas ratlos und vermuten ein W-Lan issue...
    Aus meiner Sicht ist aber alles soweit ok:
    Shelly EM:
    {"wifi_sta":{"connected":true,"ssid":"WL-912149713_2GEXT","ip":"192.168.0.128","rssi":-61},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"10:21","unixtime":1686817278,"serial":5,"has_update":false,"mac":"349454745E22","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"is_valid":true,"source":"input"}],"emeters":[{"power":-491.18,"reactive":-22.39,"pf":1.00,"voltage":237.30,"is_valid":true,"total":0.0,"total_returned":302594.0},{"power":0.00,"reactive":0.00,"pf":0.00,"voltage":237.30,"is_valid":true,"total":0.0,"total_returned":0.0}],"update":{"status":"idle","has_update":false,"new_version":"20230503-102005/v1.13.0-g9aed950","old_version":"20230503-102005/v1.13.0-g9aed950"},"ram_total":51064,"ram_free":36672,"fs_size":233681,"fs_free":157377,"uptime":989}
    Shelly 3EM:
    {"wifi_sta":{"connected":true,"ssid":"WL-912149713","ip":"192.168.0.103","rssi":-58},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"10:30","unixtime":1686817814,"serial":24632,"has_update":false,"mac":"244CAB41A273","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"is_valid":true,"source":"input"}],"emeters":[{"power":8.31,"pf":0.51,"current":0.07,"voltage":234.35,"is_valid":true,"total":488715.9,"total_returned":0.0},{"power":31.48,"pf":0.41,"current":0.33,"voltage":233.76,"is_valid":true,"total":628008.4,"total_returned":0.0},{"power":-83.09,"pf":-0.52,"current":0.68,"voltage":234.49,"is_valid":true,"total":1891279.6,"total_returned":44047.2}],"total_power":-43.30,"emeter_n":{"current":0.00,"ixsum":0.83,"mismatch":false,"is_valid":false},"fs_mounted":true,"v_data":1,"ct_calst":0,"update":{"status":"idle","has_update":false,"new_version":"20230510-083155/v1.13.1-gda6f9f2","old_version":"20230510-083155/v1.13.1-gda6f9f2"},"ram_total":49920,"ram_free":30876,"fs_size":233681,"fs_free":154616,"uptime":1079957}
    Beim EM und 3EM habe ich folgendes gemäß HA modifiziert:
    Die Empfangsstärke scheint mit ausreichend zu sein. Auch sonst sehe ich keine "Abweichungen".Was meint Ihr?
    Gruß aus Wien
    Rudi
    2 Mal editiert, zuletzt von Valsi (15. Juni 2023 um 10:42)
  • Von welchem Shelly wird der Energy Export Daily verloren vom EM (Uptime: 989) oder dem 3EM (Uptime: 1079957)?
    Ich habe bei mir bei allen shellys der Gen1 color direkt auf HA laufen.
    Beide verwenden einen anderen AP, evtl. gibt es auf dieser Strecke abbrüche?
    Hast du die Hauseigene Shelly integration oder ShellyForHass?
  • Mir ist (als HA Beginner) nicht klar welcher Shelly den Sensor Energy Export Daily liefert. Wenn ich bei den Geräten jeden Sensor anklicke, dann finde ich keine Unterbrechung der Kurven..
    Was meinst Du mit AP?
    Ich ahbe die Hauseigene Shelly Integration.
  • Energy Export daily
    Dieser Sensor kommt nicht direkt vom 3EM/EM
    Das Wort „daily“ sagt ja schon das Wort => Täglich
    Daher sollte er auch jeden Tag neu beginnen 😎
    Frage ist, wie du ihn erstellt hast 😉 auch HA macht das nicht von alleine
  • Dieses Thema enthält 48 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
