Wrong prefix for consumption and returned
  • I just installed the first EM3 last weekend and the manual stated to put the amp clamps from K -> L which states K as the power delivery and L as your home consuming power.
    I did exactly that an installed the clamps between the first fuses and the grid power meter.
    The values itself are correct or at least seem to be correct but the prefix is wrong - the shelly app shows a 25kwh consumption and 4.5 kwh returned. But it's simply the other way round. The PV delivered about 30 to 35kwh and in the morning the house consumed about 4 kwh.
    So the values match the values on the meter but the app shows the consumption as "returned" values.
    I'm sure I didn't mess up the direction on of the clamps - is there anything else I could have done wrong?
  • There is some confusion with the label on the current clamps and the manual! Please turn the clamps over till the display is correct!
  • So this will be fixed in the future? If that's the case then I'll stay with the direction as is, as the installation of the clamps was complex.
    I'll just see if the values change in the future.
    Thank you for the response.
