Set dimmer2 light from HA
  • Hi, i have OverTemp problem with my dimmer 2 when light is between 70% and 99%.
    I'd like to create an automation in HA that reduce light to 65% if temp is > 98C° and light is ON.
    But i dont know how to set an EVENT to set light at 65%. I i can do it?
    Thanks
    alias: DimmerOverTemp
    description: In caso di alta temperatura imposta luce al 65%
    trigger:
    - type: temperature
    platform: device
    device_id: 9758227197bec1ce6b8efab3dexxxxxx
    entity_id: sensor.dimmer_device_temperature
    domain: sensor
    above: 98
    for:
    hours: 0
    minutes: 0
    seconds: 5
    condition:
    - condition: device
    type: is_on
    entity_id: light.dimmer
    domain: light
    action:
    - event: ""
    event_data: {}
    mode: single
