missing function Input State Display
  • Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Application Settings
    Consumption Calculation
    Click the checkbox to exclude Shelly Device from total room consumption. Click the other checkbox to exclude Shelly Device from total account consumption.
    Pin Lock
    Enable and set a device pin lock.
    Sync Name
    Keep the device name in sync with the name given in the app.
    Input State Display
    Turn on indicator for the current status of the physical switch connected to Shelly Device. When enabled, a small line appears on the power button, below the power symbol . A red line indicates the physical switch is off, while a blue line indicates the physical switch is on.
    Exclude From Event Log
    Do not show event log reports for this device in the app.
    Share
    Input an email and share control of the Device with another Shelly Cloud user. The other user will only have access to the Device's power button (on/off), and be able to see the Device Information. The other user cannot see the other device settings.
    Ich bin Elektrotechnikermeister:
    Meine Kommentare zum elektrischen Anschluss sind grundsätzlich zur Weitergabe an Fachpersonal gedacht und stellen nur eine theoretische Diskussionsgrundlage dar!
  • Hmm. It seems that this option is missing on some (or all?) other devices too. On one of my older 1pm‘s it is currently activated, because I have enabled it a long time ago, but I’m not able to deactivate it. So this indicator works in the web-view without any chance to de-/ activate it.
    De-/ activating via app doesn’t change anything on the web-view, but works normal in the app.
  • none of the fanboys noted it
  • I think, most user use this in the app, and not directly in the web-interface. So nobody noticed this missing option.
