Dimmer won't turn off
  • I just got my first dimmer and installed it to some leds in my living room. The problem is that the leds will not turn off completely when I turn it off in the app or on the physical switch. It only dims down to maybe 40% and when I dim it down to 1% it's still very bright.
    Is the dimmer broken or is something else wrong?
    It's connected to 17 leds with a total of 153 watts.
    Did you calibrate it?
    Maybe you have entered a value in the settings under Minimum Brightness?
  • Yes, I calibrated it two times and there's no minimum brightness set. Any other ideas?
  • Seems like the Shelly Dimmer is a little bit buggy. If i turn on the lights through the app the minimum brigthness is correct, i've set it at 13% and it stays like that everytime.
    Turning on the lights through the physical wall switch then it also shows 13% in Shelly App also. But the light is incredibly lower than when turning it on through the App instead.
    Turning on the light through the Home Assistant Integration it shows the same behaviour as i would turning it on through the Physical Switch.
    Some facts: Turning it on through the Shelly App it shows 2.7w on 13% brightness. If i turn on the light through the Physical and Home Assistant it shows 2.4w on 13%
    Calibration and everything like that has been done.
    So clearly there's a software bugg
