Settings via the web interface
  • I have shells plus 1 (controls the pump) and shells 1 PM (controls the heater) to my home network. The shells have fixed IP addresses in the network with numbers at the end of 105 and 106. I want to control the pump after turning on the boiler without the cloud and the application, only by setting it in the web interface. I can't set it up. Can anyone advise me? Thank you
  • Hi,
    Do you mean that you want to effectively link the Shellys, so when you turn on the heater the pump is automatically turned on, and the same for off?
    You can set this up by creating actions on the "master" Shelly, one for on and one for off. The actions need to call a url, which is:
    http://<IP of "slave" shelly>/relay/0?turn=on
    I am using this to link multiple lights together, and the response times are good.
  • Here the Lexikon Link:
    HTTP-Request - overview
  • Hi,
    Hello,
    yes, I want the function you describe.
    I tried to set this up according to the instructions but it doesn't work for me?
    Do you need to set up something in your home network?
    I also tried the command http://192.168.x.x/rpc/Switch.Set…oggle_after=300 but it also doesn't work.
