Shelly 2.5 not accepting Toggle via URL
  • Hi
    I have two Shelly 2.5, one of them connected to a light and the other acting as virtual parallel switch. It was working fine until somedays ago.
    I have at the virtual parallel switch, at the Button switched ON url the following URL http://10.2.2.5/relay/0?turn=toggle. The same goes for the Button switched Off url. When I toggle the switch physically or via the app, it doesn't turn on or off. If I use a browser URL and use the same command it does work.
    The wifi seems fine since I can access both devices via browser or app. Both devices are with the latest firmware 20221027-092056/v1.12.1-ga9117d3
    Any ideia why it is not working ?
  • No, I toggling another device, the primary that is connect to the lamp itself.
    Einmal editiert, zuletzt von Gast10 (24. April 2023 um 16:56) aus folgendem Grund: Not needed fully quote of last posting deleted. Please don't do so. Tanks
  • Andre_Martins 24. April 2023 um 19:05
    Hat den Titel des Themas von „Shelly 2.5 no accepting Toggle via URL“ zu „Shelly 2.5 not accepting Toggle via URL“ geändert.
