Dimmer vs Led Tapes
  • Hey Shelly guys!!!
    I connect the Shelly dimmer 2 with dimmable led tape and the lighting does not dimming . It flashes when the brightness reaches below 50% and the relay sounds loudly until it appears in the application that the device has raised temperatures and must be switched off!!! =O =O =O
  • Would you please give us type and manufacturer of the LED strip and the power supply?
  • Thanks for the data!
    Issue is the CV power supply, which is not dimmable:
    Even a Shelly RGBW2, which is working at the secondary (low voltage) side of the power supply doesn’t help: Obviously, the strip consumes too much power and would overload the RGBW2. Sorry…
    Addendum: Assuming you‘re using this strip:
    Cubalux Led Strip 14.4kWh/1000h/m 12V dc Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    we need to know how long the strip is. If it is a 5 meter strip, power consumption would be about 75W (one channel), which doesn’t correspond with the max. power of 45 W per channel of an Shelly RGBW2 with 12V supply.
    Einmal editiert, zuletzt von thgoebel (6. April 2023 um 13:19)
    The shelly bypass component that can be used?
    Also, now I notice that in my application it shows that it is offline. I've reset it I'm trying to reconnect it to the cloud and nothing changes… :(
