shelly 1 cant assign room
  • I have installed 4 shelly 1 devices as a trial run got everything set up and so far I'm impressed however 1 device allows me to add to the app but not assign to a room.
    I can even switch on and off from the app so the shelly is working but when I try add to room I get "error could not get device info connection to device lost.
    wifi signal shouldn't be the issue as I have another shelly 1 installed in the same location.
    have made several resets but always the same issue.
    Welcome to the forum ??
    I've never heard of such a problem.
    You could try clearing the app's cache and data, and then restart the app.
  • Hi
    I'm new to this and i just got my first shelly, a Shelly plug S.
    With much effort i maneged to add new device. It worked as far as to turn it on/off via app. But I can't add it to a room. I get same error message as described above.
    I tried clearing cache and app data. Didn't help.
    Any other solution to this?
    Thanks
    does the Shelly have internet access? Easy to see when you call up the Shelly's WebUi and a time can be seen in the top right corner.
