Shelly with Solar Power & Heating
Hinweis für Entwickler
  • Hi Shellylovers!
    Is there a way to limit the A that go through the shelly?
    I am planning to heat water with a solar array. The water heater however can soak up to 3kwh Power at once.
    I would like to synch that with the power production of the solar array.
    Anyone had this problem before?
  • Is there a way to limit the A that go through the shelly?
    Hello,
    this is not possible.
    While it's not possible to regulate the current to a specific value through a Shelly relay, a maximum current can be set or measuerd. If the set maximum current is exceeded, the Shelly will shut off and generate an overcurrent alert.
    However, repeatedly turning the heater on and off at a certain current via a skript is not recommended because the water heater is an inductive load. This can cause voltage spikes and potentially damage both the Shelly and the heater or even more. Therefore, using a two-point controller method with Shellys for a water heater is not recommended. Additionally, it's worth noting that Shelly smart relays are primarily designed for controlling resistive loads and may not be suitable for inductive loads like water heaters at all.
    In theory you could write a script to turn a Shelly into a two-point controller / on-off controller for a water boiler, if its a Shelly thats able to measure A. Or you could just turn the realy of if the power you are getting from your solar array is less than 3kwh.
    In practice, however, it would be a bad solution, one that would quickly lead to a destroyed Shelly or even more damage.
    12 Mal editiert, zuletzt von _[Deleted]_ (24. März 2023 um 23:06) aus folgendem Grund: no coils in water heaters
  • because the water heater is an inductive load.
    Could you explain that in detail? During my academic studies I was told heating of liquids is done generally by resistive elements…
  • thgoebel
    "Oh, my bad, you're right. There are no coils in a boiler.
    (I somehow had to think of coils, of course a water boiler does not need coils.... ^^)
    I also realized that a two-point controller wouldn't be a solution for his problem.
    It's I was thinking of a boiler when I mentioned the two-point controller, and how to keep its water at the right temperature, which led to my confused answer. :beer: Dont ask me why.
    In any case, regulating the current to a specific value through the Shelly relay is not possible. However, you could simply turn off the relay if the power being generated by your solar array is less than 3.1 kWh,
    If your solar array isn't generating more than 3.1 kWh, then it won't be possible to make this work at all. So yah a shelly is not the right solution for this and even if you are producing more than 3.1 kwh its still not a good solution.
    10 Mal editiert, zuletzt von _[Deleted]_ (24. März 2023 um 23:41)
