Control 24V DC window opener
  • Hi all,
    I’m trying to find a way to control a Velux electric window using a Shelly. Not sure which shelly is suitable, but I think the Plus 2PM might be the one.
    Specs of the actuator i’m trying to automate:
    - it is a 24v DC motor
    - the direction of the motor is based on the polarity of the + and -
    - the maximum amps it draws is 2A @24v
    Altough it looks that the Plus 2PM can switch on 24v, I don’t believe it is able to switch polarity to open or close the window.
    Based on above specs, I need a matching Shelly. Who can assist?
    Much thanks!
  • Welcome to the forum!
    To your issue: In addition to the Shelly plus 2PM (which is generally suitable) you‘ll need a commutator. This is a combination of two NO/NC relays. Some threads in this famous forum cover this issue. Please search for „Polwender“!
  • Hi! Thanks for your quick reply. I do not get any results when I search for Polwender in the searchbar. I’m using the ‘global’ search. Do you have a direct URL to one of the threads?
  • Got 52 hits using the term ‚Polwender‘:
  • I only see these two or am I using the search incorrectly? It is set to Everywhere… Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
