Are the 50A clamps smaller than the 120 A?
  • Hi
    I don't have much room in my fuse box -- I would like to install a second 3em to monitor a few circuits when the currents will not likely exceed 15A. Are the 50A clamps physically smaller than the 120A ones and therefore worth getting to facilitate the installation?
  • Indeed, the 50A clamps are smaller:
    But the 50A clamps don’t have a plug but cable ends only. To operate them with a Shelly 3EM you‘ll have to attach the plugs. Would recommend to calibrate the 50A clamps with one of the original 120A clamps, as described here:
    3EM calibration of the N-clamp
  • I am also interested in using 50A clamps on my 3EM. However in the link you provided it says that only 120A clamps should be used with the 3EM.
    If I understand your post correctly, you mean to plug a 50A clamp on N on the Shelly and calibrate it with another 120A clamp on phase A, right? And then repeat for 2 more 50A clamps.
    Can you confirm this would work and it without risk for the 3EM?
    Many thanks!!
  • The 50A and the 120A clamps are electrically identical (factor 1:3000). Only the saturation current is different. Moreover, both types have voltage limiters inside, which restrict the input voltage for the 3EM. Thus, no harm for the Shelly 3EM!
    But you’ll have to deal with the connector issue! Bought some connector housings and the contacts at a German distributor…
  • Great, thanks! Does this mean I could also use the TDK CCT261631 clamps (30A) you mentioned in another post (I'd have to change the plug so that it fits the 3EM)?
    And to use them, I simply have to calibrate them following the official instructions given to calibrate the N phase? Thanks!!
