Shelly Plus Add-On to read HC-SR04 (ultrasonic proximity sensor) measurement
  • Hello,
    I am trying to connect an HC-SR04 sensor to a Shelly Plus Add-on. My goal is to track a soft water tank's status by logging distance measurements by putting the sensor above it and pointing it down.
    I dug into the documentation and could not find relevant help. I also looked into scripting without no luck.
    Did anybody manage to do it? Will it be supported natively at some point?
  • Welcome to the forum!
    To your issue: The HC-SR04 sensor needs some time measurement (“flight time” of ultrasonic signal). Thus, you’ll need an Arduino or Raspberry to do the job.
  • Hi all,
    Can anybody confirm that this information is still correct. I had ordered a series of add-on devices, because this knowledge page shows "Ultrasonic proximity sensors" in the list of supported sensors. Therefore I thought that the hc-sr04 would be supported. So it would be real bummer if it would not be supported after all...
    Thanks!!
    Bart
  • This facebook discussion mentions that the URM09 distance sensor is supported by the add-on. That sensor has a shared trigger and echo pin, unlike the hc-sr04 sensors ;-(
    It would have been useful if the documentation had mentioned this...
    Looking at the pinout of the add-on, I assume proximity sensors like hc-sr04 will/can never be supported?
  • Now I am confused. Some Shelly related sites (like e.g. this one) sell hc-sr04 sensors "for addon plus". From that I would expect it should be working together?
    I would appreciate a lot if somebody could illuminate me.
    Because I received yesterday a series of Add-on hats as a father's day present, so it would be awful if I cannot use them...
