Hi, I am testing the Shelly Plus 2PM and its energy meter function. For this test, I decided to control the power supply of my Synology NAS in order to reduce the consumption to almost 0W. For this test I use the Shelly's switch_0.
The power consumption of my NAS is about 45-50W in normal operation and still consumes 14W in shutdown state.
By switching the Shelly switch_0 to OFF, the consumption of the NAS is almost 0W (there remains the consumption of the shelly... ). So nothing to say about it. It works.
Where I find energy meter reading error is in case the Shelly switch_0 is ON and my NAS is down. I'm supposed to read 14W while the Shelly shows me 2W. What is strange is that the Shelly also shows me the instantaneous voltage (234.6V) and current (0.059A). Applying the formula P=UI, I find: 234.6*0.059=13.84W. Which corresponds to the 14W displayed by another measuring instrument and not the 2W.
On the other hand, when I turn on my NAS, the instantaneous power value measured by the Shelly is identical to the value measured by the measuring instrument (45-50W). In the latter case, the Shelly also displays the power factor.
So, I don't know how the instantaneous power is calculated in the Shelly. But if it is a simple U*I, the value should be correct in any cases.
Any help to understand where I'm wrong is welcome.
Laurent
