shelly 1pm does not work with mains
  • Hi all,
    I recently came into shelly world and it is amazing. Anyways I bought a used shelly 1pm which was listed as working. When I received the module and connected it to the mains nothing was happening. Clicking buttons didn't work as well. When I tried to power it through the programming header with 3.3V though, the module started working. Is my module fried, or can I try to replace some parts to make it alive? I attach my module photo in attachments. The weird thing is that I know this shelly should have a switch between 24v and 230v, but mine doesn't have one.
  • See if any cracks or discoloration are visible on the fuse resistor
    Welcome to the forum. :)
  • Can you guide me which one is the fuse resistor? I couldn't find any schematic anywhere. When I look generally at the board I don't see any obvious signs of broken components. I have a multimeter so I can check if is it broken or not. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    Einmal editiert, zuletzt von mikimause9 (1. März 2023 um 21:16)
  • This
    is the fusible resistor. 10 Ω resistance.
