device disconnected very frequently
  • in a register box I have two 2.5, two dimmer2 and one plus1pm
    for several years they have worked without problems.
    but since a month or two. a 2.5, always the same, stays offline more and more frequently.
    I have tried turning off power saving.
    also to activate roaming. varying the threshold in various tests. no effect either.
    I have also tried to open the box and reposition the devices.
    neither. the result is always the same.
    After a while the device disconnects and I have to cut power to bring it back to life.
    the signal level is around -45db inside the box.
    the devices communicate by coiot in unicast to ha.
    In the house there are several devices, this being at an intermediate distance from the access point in relation to the others.
    any suggestions?
  • At least one electrolytic capacitor in the Shelly 2.5 has probably lost it‘s capacitance, Some facts about this issue are written here (unfortunately in German language):
    thgoebel
    15. April 2022 um 10:34
    With some skills in soldering (better more desoldering) it is possible to replace the parts.
  • Well, I finally broke it.
    indeed the capacitors were dry and gave very little capacity.
    but they are so small! so assuming the two 4.7's were in parallel. I have put one of 10. but no.
    has melted the resistance.
    so I'll take advantage and buy a pair of 2plus
