Replacing Eltako s12-100-230 connected to 3 Momentary Switches with Shelly Dimmer 2
  • Hello,
    can anyone let me know how I can replace a Eltako s12-100 with 3 Momentary Switches connected to it using 1 cable with a Shelly Dimmer 2 and how to wire correctly?
    Attaching a picture from my setup (both N cables will be bridged and connected with a single cable to the Shelly btw.)
    I was thinking the right way would be as follows but would appreciate some confirmation please:
    • input L Phase 230V (upper left brown cable) of Eltako goes into L of Shelly Dimmer 2
    • input +A1 (upper right brown cable for Momentary Switches press) goes into I1 of Shelly Dimmer 2
    • bulbs output (lower left grey cable) goes into O output of Shelly Dimmer 2
    • N cables (left right two blue cables) goes (bridged with a Wago) into N of Shelly Dimmer 2
    Externer Inhalt lh3.googleusercontent.com
  • Welcome to the forum!
    The Shelly Dimmer2 has no explicit „momentary“ setting, but you may choose between one and to button mode:
    For your application, the one button mode should fit…
    thank you. I have more than 2 switches and I think I've set it to dual Button mode at the beginning but the switchs have all of the sudden stopped working. I thought maybe it's because of a firmware update or something like that.
