Bluetooth Gateway Active Connection
  • Dear sirs
    I recently discovered that Shelly Gen2 devices act as bluetooth gateways in Home Assistant which is great news.
    So i test that with some Mi Flora and some Mi HT Sensors and Shelly succesfully passed the bluetooth device in Home Assistant.
    Now i got a SwitchBot Bot which is bluetooth but Home Assistant doesnt recognise it. Offcourse i have configured the Specific Shelly Plus 1PM in Home Assistant to be Active as gateway.
    If i use an M5Stack bluetooth gateway, the switchbot bot works fine in Home Assistant.
    Anyone has any clue why this is happening? Is this a problem with the Shelly Device or Home Assistant even if it asks you how to configure your Shelly to be Active or Passive bluetooth gateway, this isnt working?
    Thx
    Chris
    There's no substitute for experience.
  • Thank you for the information, do you know if it will ever be supported? it will be great addition to our beloved Shelly's :)
    Einmal editiert, zuletzt von Gast10 (23. Januar 2023 um 05:15) aus folgendem Grund: Fully quote of last posting deleted. Please don't do so.
  • Afaik shelly is only working as a passive bluetooth gateway.
    I use it for ruuvi-tags and this works fine to transport the ruuvi data to my MQTT-broker.
