Light Flashing
  • Shelly Plus 1 - Flickering Light
    Hi all,
    Looking for a little help. I am installing a Shelly Plus 1 to control my bathroom extractor fan. I'm UK based. Currently when you switch the bathroom light on, the fan comes on too. I want it so that the fan can come on/off based on a number of scenarios etc.
    Coming into the fan currently are Live, Switched Live and Neutral.
    I have wired it as below in the first picture. Top is how it is currently wired to the fan, bottom is with the shelly in place.
    Second picture is the wiring from the physical switch to the light and the fan etc. Everything is the same, but my system doesn’t have an isolator.
    Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. It works and I am able to control the fan as expected, however, when the physical light switch is off, the light in the room flickers. I swapped out the bulb and it doesn't flicker now, but it is dim and always on.
    What could be the cause here, is it something I am doing wrong?
    Thanks!
    Einmal editiert, zuletzt von charlietburton (16. Januar 2023 um 16:30)
  • Welcome to the forum!
    To your question: Would you be so kind to amend your sketch with the wires to the lamp and the physical switch? This could help to understand the issue!
  • Hi - welcome to the german shelly forum.
    I've some questions.
    1. How the lamp is switched/dimmed (physical switch type) ?
    2. Is it a smart lamp like Philips HUE or so ?
    Without wiring diagram it is difficult to make a remote diagnosis 🔍
    elektroman:~#
  • charlietburton : Many thanks for the additional diagram! The flickering of the lamp results from the SW-input of Shelly plus 1. Try to swap the wires at pins L and N of SHELLY, leaving the other wires at its place!
    Einmal editiert, zuletzt von thgoebel (16. Januar 2023 um 17:37) aus folgendem Grund: Typo amended
