HTTP Call to a Shelly 1 PM Plus with authorization ends in Error message "Invalid argument 'headers': length should be less than 128!"
Hinweis für Entwickler
  • Hi,
    i have some issues when calling a Shelly 1 PM Plus from another shelly via HTTP Request:
    i want to switch the shelly off :
                let url = '{"method": "GET", ' +
                  ' "url":"http://admin:asdfasdfasdf@10.2.103.215/rpc/Switch.Set?id=0&on=false", ' +
                  ' "headers": {"Authorization": "Digest username=\\"admin\\", response=\\"6df8a5a2328b4a43eb5abedf0fasdfasdf47f876c85ecf1asdfasdfe9eb5ac33\\", qop=auth, algorithm=SHA-256"}' +
                  if(DEBUG_LIGHT_TOGGLE)
                    print("url = " + url);
                  Shelly.call( 'HTTP.Request',
                  url,
                  function callback(result, error_code, error_message, userdata)
                        print('ANFANG Regal callback off');
                        print(JSON.stringify(result));
                        print(error_code);
                        print(error_message);
                        print(userdata);
                        print(result.body);
                      if(result.body !== undefined)
                        let a = JSON.parse(result.body);
                          print('r.isOn=' + JSON.stringify(a.ison));
                          print('r.brightness=' + JSON.stringify(a.brightness));
                      else
                        print('ERROR: result.body = UNDEFINED');
                      print('ENDE Regal callback turn off');
                  null);
    but in the Logs i can see an error:
    url = {"method": "GET", "url":"http://admin:asdfasdfasdf@10.2.103.215/rpc/Switch.Set?id=0&on=false", "headers": {"Authorization": "Digest username=\"admin\", response=\"6df8aasdfasdfdf0f537eecf7b47f876c85ecf1asdfasdfasdf9eb5ac33\", qop=auth, algorithm=SHA-256"}}
    null
    -103
    null
    at script_1.js:465
    at api_rpc.js:8
    RPC cb error: type error
    the Shelly 1 PM Plus is configured with authorization via "Device -> Authorization -> auth password".
    if i remove the authorization i do not need to supply the authorization header, so i do not exceed this limit.
    is there a better way to do auth and change the state of the relais?
    thanks for every hint!
    best regards
    Alex
