3EM on 3phase main switch - all other fuses are one phase
  • Can Shelly 3EM be used in my setting: Main switch/fuse is 3phase, but all other fuses are one phase where the goal is total consumption measurement?
    Do I have to buy and replace 3 of my one phase fuses with 3phase fuses to have 3EM to give me total consumtion?
    I have tried to read everything about this matter, but can't find simular case.
  • If you supply your premises with only one phase, you would need a Shelly EM only! But have a look at the Forum's lexicon area: IIRC, there are some connection diagrams for Shelly 3EM with one phase only...
  • Thanks thgoebel - in this rainy afternoon.
    I live in Norway and we have not "N", but use two phases to get 230 volt. I found a connection diagram with 2 phases, but as I think my electrician to have connected all 3 phases in the main switch - each to random one phase fuses, I suppose we should connect the 3EM to exact the same phases (fuses).
    My question was also if I must buy 3 phase fuses. But possibly NO as you didn't reply to that.
  • Found two threads treating the "no neutral" issue:
    JanVG
    21. September 2022 um 12:53
    and
    barry2002
    19. September 2020 um 05:41
    To your second question: Must admit I didn't get the point! Why should you buy three-phase fuses if you have two phases only (and no neutral wire for 230V appliances, as I assume)?
