Shelly app used to work locally ... meaning with non-cloud enabled devices.
When will it be re-enabled ?
PS: I use MQTT which disables cloud
the App is named "Shelly Cloud", so I'd assume Cloud usage is mandatory ![]()
If you're using MQTT you'll probably have a smarthome system such as ioBroker, HomeAssistant or OpenHAB installed? (all of them have their own Apps which are working well).
Why MQTT and not CoIoT (Coap) where cloud is still working? Most smarthome systems support both.
Thanks, MQTT is rather universal and I have other personal code that publishes to MQTT which is picked up by the shellies.
The thing is ...before ... Shelly supported access between their app and shelly devices on the same Wifi without activating the cloud. That has been disabled which is a shame.
I don' know where Shelly store there cloud servers .. another app to delete from the phone.
Cheers
The main reason I started with shelly was the possibility to use them in local network without a cloud and with their own app . Realy plug and play !!! Fantastic.
And now this main reason disappeard.
Connecting localy ocer the IP address still works but not the app.
WHY ????
This is working really great. Your app device and Shellys have to be in the same Network.
