default settings for color and temperature
  • Hi,
    any solution for shelly color DUO RGBW bulbs, to back to the "default" color or white mode after switching on/off with the wall switch?
    For instance, bulbs are set as White color most time. When i change to a color in the app and turn it off by regular wall switch i would like to back to white color when i switch on the wall socket. Is it possible?
    Or possibility to set bulb that always start with White 100% for instance
    2 Mal editiert, zuletzt von saybot (27. Oktober 2022 um 15:30)
  • saybot 27. Oktober 2022 um 14:46
    Hat das Label von Shelly Bulb auf Shelly DUO geändert.
  • There is no such function on the Shelly Duo. An option would be to install a Shelly 1 or i4 behind the light switch, for example, where the switch is connected. You hang the lamp cable in the flush-mounted box directly from phase, so that you have constant voltage on the Shelly Duo. Now you can turn the duo on or off with Http commands. If you have a button, you can even store several things with an i4.
  • So if I understand correctly.
    There is no way to configure "default ON state" for Shelly bulbs, if you use conventional switch which cuts the power?
    Lets say I turn power ON on wall conventional switch. Can I set in what mode bulb lights on (lets say: blue color, with 50% dim)?
  • There is already a Power on default option for on. But it then starts in the last mode as far as I know.
