Does Shelly Cloud api support Bulk Control to update Schedule Rules?
  • I'm developing a mobile app where I need to update the schedule of several Shelly Plug at the same time.
    Since there are about 40 of them, making a request to update 1 by 1 is very costly in terms of efficiency.
    Is there a way to do it through bulk control in 1 single request?
    Best Regards!
  • Yeah you can write a script, here are the API docs https://shelly-api-docs.shelly.cloud/gen1/#shelly-p…ettings-actions
    Here I have written about schedule_rules on TRV sorry in German, but the url's should be nearly the same TRV - Schedule Rules API
    http://192.168.XXX.XXX/settings/relay/0?schedule_rules=0830-0123456-18.5,1030-0123456-20.5
    You have to change thermostats to relay and remove schedule_profile from URL the rest is nearly the same. I'll try to translate the 0830-0123456-18.5 code for you
    First Block (0830): HourMinute
    Second Block (0123456):
    0 = Monday
    1 = Tuesday
    6 = Sunday
    so 0123456 is Monday to Sunday
    Last Block (18.5): at TRV this is temperature 18.5°C,
    So I think you have to replace this with something like on or off
    Best option would be to set the rule for one device and get the scheme from http://<shellyip>/settings/relay/0
    But I hope this helps you
  • Hello, thanks for answering
    I'm currently able to set the schedule_rules via the shelly-cloud API, by doing a POST to:
    https://<my-account-access-domain>/device/relay/settings/schedule_rules
    to which I send the data:
    - auth_key
    - go
    - enabled
    - channel
    - schedule_rules
    With that I can easily set the schedule of the device. What I need is a variant to run a BULK to update multiple devices at once. Do you know if that function is available in the shelly-cloud API?
    Thanks again for the help!
