Measure cold water consumption (1L=1impuls)
Aufgrund technischer Probleme kommt es derzeit zu starken Verzögerungen beim Versand von E-Mails. Weitere Informationen unter https://status.shelly-forum.com.
  • Hello,
    On cold water flow meter is one impuls output (which give 1 impuls for each 1 liter).
    How can be possible
    1. To measure such water flow with Shelly device (which can count the pulses).
    2. How can be possible to show in graphical interpretation instead e.g. /celsius degree or watt/ the /Liter or m3/? Additionaly setable ratio will be helpful (becuase are exist more solutions, e.g. 1Liter=1imp, 10Liters=1imp, etc.)
    3. Wifi connection will be required. Connect to 230VAC or battery is preferred (one is enough). Installation to water shaft.
    Thanks in advance.
  • Welcome to the forum!
    To your issue: What is maximum water flow per minute (or per hour)? This value should be known to determine the maximum pulse frequency…
