In one of the connection diagrams, there is a note "tTo protect the tubular motors use a shutter switch!(Locking)"
Is the "shutter switch" the buttons on the wall, original?
Tks
Tks
It is recommended to use a shutter switch because mechanically it does not allow simultaneous switching of both channels. Although the Shelly 2, 2.5 or Plus2PM has this protection on the software side, if the Shelly is in relay mode for whatever reason, normal buttons/switches could damage the roller shutter motors.
I thank for the explanation!
So if i purchase the 2.5 i have to worry with this issue!
And by the way wihch device should i install with it?
Best regards
You don't have to worry, I don't know of any case where the Shelly 2.5 destroyed a motor in shutter mode. This is purely a recommendation with the roller shutter switch, but not a must. As a rule, there are roller shutter switches from all common switch programs from the respective manufacturers.
OK!
Thanks again!
Best regards
