How to interpret EM data
  • Hi, I have been using an EM for several months now, monitoring the power cable going to a robot mower charger / base station. From the myShelly screenshot below, what do the various values mean?
    The -65 W will be the current draw (the mower is charging), and that makes sense.
    The Returned - is presumably the cumulative number of Watts that has been measured since install?
    If so, then the Consumed is presumably zero because no back feeding of power ever occurs?
    I also bring the data in to Home Assistant, and that gives the data below. But I am not sure what is meant by Energy and Energy Returned. Or why the Power is different from the -65 W in the first screen shot.
    Any help in explaining the data would be much appreciated.
  • This is a negative value. Turn the clamp the other way around. Consumed should be consumption in the selected time. And Returned would be infeed, that's where the 0 should be.
