TWO TRV in one Room
  • Hello,
    two TRV are located in one room, mounted on separate radiators.
    Can they use the actual mean temperature value of both devices as reference value?
    How to create a weekly schedule on one TRV and use the same schedule on both devices, without manually copying/entering it in the second device?
    Thank you very much for your time.
    current_runner
  • This does not work with pure Shelly software and only TRV. You have to add a Shelly H&T, whose temperature the two TRV's take as the temperature value.
    Unfortunately, it is also not possible to copy the time programs stored by Weekley Schedule from one TRV to another. Unfortunately, the only thing that helps at the moment is to send a future request to support that something like this might be possible at some point. I think something like this is also needed with several TRVs throughout the house, it is very cumbersome and time-consuming to make corrections.
  • Hello,
    is it possible to add the schedule to a group of TRV to make two TRV synchron in time?
    Is it possible to make a TRV the chief (with programmed schedule) and a second TRV the worker (getting desired temperature from chief)?
    Thank you
    current_runner
  • Unfortunately that doesn't work either. Each TRV must be entered separately into the Weekley Schedule. You can create a group with several TRVs in the app and control them together for common manual temperature changes. But unfortunately we can't do more than that. It is also not possible to set a TRV as the master device. Allterco still has to make significant improvements here.
