Temperature warning
  • Hi,
    I have a number of Plug S 2500W to measure my equipment at home.
    - Washing machine
    - Dryer
    - Dishwasher
    - Drying Cabinet
    - TV/Media set
    I had them installed for at least 6 months and yesterday the washing machine plug sent a push, warning for high temperature and turned itself off.
    I went over there and it was really hot. I have set the safety limit to 2200W.
    After some giggling I managed to unplugged the device and found that it had started to melt the plastic around one of the connectors (see pic).
    Is this a faulty device or anyone seen this before? I am not even maxing the device so I was not expecting it to behave this way.
    Anyone else seen this? Should I send it in and claim a replacement device?
    Thanks for your views!
  • Welcome to the forum!
    To your issue: Obviously, one pin of the Shelly plus S did get quite hot. In most cases this is induced by a faulty plug socket. Please double-check if the contacts in the socket are worn, bent or otherwise damaged!
  • Thanks for the welcome!
    I have checked the socket and I find no issues there and it does not get warm when not having the Plug S in between.
    So seems like the heat is generated in the Plug S.
