The instructions clearly show a switched Neutral, unless im being completely dumb.
UK Ring circuit, Wago's used to connect on the right, cables as shown
Socket Tester not happy showing a Live/Earth Reverse ?
What am I doing wrong here ?
Welcome to the forum!
To your issue: Due to the fact, the relay contact in the Shelly switches across terminals L and O of Shelly, neutral is NOT switched in this arrangement. You’ll have to connect the blue wire to the socket at the Wago with the neutral wires (use a 5 pin Wago) and the brown wire to the socket at terminal O of Shelly.
Addendum: In the forum‘s „Lexicon“ are some diagrams to find for (nearly) each application:
Not usre I understand...that is not what the printed wiring diagram shows on my 1PM's....My picture is an actual photo of the units I have...doesnt show any connection between L and O ??
Don’t understand this. Would you please precise your statement?
The printed connection diagram on my Shelly is very different to that shown in the Lexicon......
Mine looks like N is connected to O with a bulb
And the L's are connected to SW
So should I be taking the L into an L and out of the SW ?like the amended diagram ?
