ShellyS - Cant update firmware
  • I bouhgt four ShellyS plugs and downloaded the IoS application. The application finds the plug and tells me it needs to update the firmware. After a while it says the same thing again and again and I can never update the firmware. I browse the IP-adress of the plug and it tells me that there is no newer firmware available. I have no clue how I can get past the update message on the IoS app. Any suggestions?
    As an update, I am trying to manually update the firmware using the Shelly Firmware Archive Link Generator (shelly-tools.de). regardless of what firmware i select and flash, the original remains.
    "The current Firmware version of your Shelly device is 20190516-073020/master@ea1b23db No newer firmware available."
    2 Mal editiert, zuletzt von tinyvaldemar (14. September 2022 um 20:48)
  • Same issue here. Also tried the manual update and no luck there. Also tried what devil suggested but that didn't work aswell.
    Update link looks like it works since i can see it triggering the LED's but opening http://<ip>/longifyid gives me a "not found" page. So i did a manual factory reset with the long button press but after that all is the same as before. Firmware is the same and update also fails from the app (stuck in endless updating status)
