Turning non-wifi thermostat into wifi thermostat with shelly INU
  • Hello there,
    I am new to Shelly universe and I do not understand anything about power wiring. I have some shellys on my plugs around the house, but someone wired the first one for me and I copied the setup for the rest of plugs.
    Now I have some new thermostats installed when I renovated my house, these are good, allow me to select a temperature and they turn on and off automatically, BUT these do not have WI-FI, so I cannot control them from a distance, nor I can have the temperature information stored or consulted from a distance.
    I tried to figure from the Shelly universe which device could help me to gain a connection to these thermostats and I am wondering if Shelly UNI is the one, but I cannot interpret the wiring diagrams myself.
    This is the wiring diagram from my thermostat:
    This is the diagram for the Shelly UNI - which I have no idea how to read:
    Can someone help me understand if the Shelly UNI is a good option for me to have remote access to this and if YES, how should I do the wiring between the Shelly UNI and this thermostat?
    Drawings for instructions at a dummy level will be much appreciated.
    Thank you very much.
    Regards,
    Inês
  • Welcome to the forum!
    To your issue:
    Due to the fact, you’ve an application with mains supply and 230V AC consumers, a Shelly UNI is not recommended. Would propose to use a Shelly 1 with Add-On and temperature sensor(s) and to replace the installed thermostats:
    316-ar768-ds18b20-png
    195-ar768-ausschaltung-png
  • Hello,
    Thank you very much for the answer :)
    I don't want to replace the thermostats, they have less than 1 year and were not cheap. Also, they measure the temperature, they are programable by hour or temperature, the only thing they don't have that I wish they had is WIFI. The boxes in the wall behind the thermostats are quite small, so it's difficult to put a Shelly in there.
    But thank you so much for the suggestion, I will keep searching for solutions.
    Regards,
    Inês
