Shelly Could response isok True also when the devices are offline
  • Hi,
    I'm using the Shelly Cloud to control (turn on and turn off) two Shelly devices from an Android application that i'm writing.
    I've two Shelly 1.
    I'm using this server "https://shelly-41-eu.shelly.cloud".
    In my request i'm sending :
    HashMap<String, String> params = new HashMap<String, String>();
    params.put("auth_key", auth_key);
    params.put("turn", turn);
    params.put("channel", channel);
    params.put("id", id);
    When the WiFi network that gives connectivity to the Shelly devices is ON all works fine.
    If the WiFi network (that gives connectivity to the Shelly devices) is OFF I get this response from the Cloud:
    {"isok":true,"data":{"device_id":"3494546a9___"}}
    The parameter isok has the value set to TRUE! Why?
    The Shellys (without a Wifi) are unreachable, the response (isok) should be return false as value.
    Also after 30 minutes of Wifi absence, the response is always true.
    I'm doing something wrong?
